Looks like my 580C has the shorts pins and bushings for swing to boom tower. They are also worn out, so looks like I'll have to retrofit the long pin. Which is a bummer because those hoses are in pretty good shape still. I wonder if there are any aftermarket short pins anywhere.I have a 580B, been a while but I got my seal kits from equipment parts store; here's their 580C seal page
Case 580C Seal Kits Application Chart
Your best source for - New Aftermarket Parts, Hydraulic cylinders, seal kits and packing for Case and other makes of construction and utility equipment.www.epsstore.com
Prices are a LOT higher than when I bought mine (surprise...)
There's also Broken Tractor -
Case 580C (Late Style) & 580D Hydraulic Cylinder Seal Kit Package
Upgrade your Case 580C & 580D backhoe with our comprehensive Hydraulic Cylinder Seal Kit Package. High-quality Bulldog or Hercules seal kits for a successful rebuild.www.brokentractor.com
In EITHER case (pun NOT intended, but I'll take it :=) be REALLY sure which cylinders YOUR machine has, split piston or 1 piece piston - may need to disassemble BEFORE you buy - The B and C could have EITHER type.
Hoses - I agree on getting them made locally - ONE MORE CAVEAT; on the hoe boom, the 580B had separate short pins and bushings (one set per side) coupling it to the swing tower; not sure about the C model, it may ALREADY have a 1 piece LONG pin thru both sides of the boom - if your boom pins are the short ones, you can't get those any more - I found this out the HARD WAY, had to buy a LONG pin/bushing kit, STILL haven't changed that out because my hoses aren't LONG ENOUGH to reach AROUND that long pin (instead of BETWEEN the two short, worn out ones)
Bottom line: check this out on your C before you buy hoses...
Also, you might find a cheaper price but if you're gonna re-seal the entire hoe (12 cylinders total on the C) this tool will probably save you an hour or two PER CYLINDER when installing the internal rod seals -
Kit King - Rod Seal Install Tool Set - 5 Piece Hydraulic U-Cup Twistor Installation Tool Set: Amazon.com: Tools & Home Improvement
Kit King - Rod Seal Install Tool Set - 5 Piece Hydraulic U-Cup Twistor Installation Tool Set: Amazon.com: Tools & Home Improvementwww.amazon.com
I did about half the seals on my 580B BEFORE I bought the tool, the "before" seals took at least an hour more than the 2 I've done SINCE.
HTH... Steve
Good news is that my machine has the single piece hydraulic pistons.
I really appreciate all the great advice from everybody. More good information than I ever expected.
