580 CK Differential Hub
/ 580 CK Differential Hub #1
DennisPayson
Payson, AZ
Case 580 CK
I have a late 60's, early 70's Case 580 CK. Had to replace the ring and pinion. I soon discovered that a spider gear fell out due to the roll pin shearing. This allowed the pin holding the spider gear in (there are three spider gears) dropped out along with the spider gear. As this happened, something jammed up and cracked the differential hub. Not sure if this was a separate problem or this caused two teeth on the ring gear to break. Either way I was able to find a new ring and pinion through "Broken Tractor". My problem is the hub. Had a machinist tell me the metal is cast and can't be welded. Thought I had a used replacement from "Worthington Ag" based on the part number (F1088) that was stamped on my hub. The part they sent me (to the tune of $480.00) was for a Case 530. My problem is finding a used differential hub. I'm trying to add a picture to this post. Any ideas?
/ 580 CK Differential Hub #2
What exactly is the difference in the two..?? What I'm seeing in the online parts book, is the early versions were riveted, later bolt on ring gear. I'll assume your's is bolted. When I ran a part number search, the F1088 crosses to several other numbers, and used in a 580CK, but was also used in a 430, and 530.
When I checked the 580C, against the 480C like I have, the differential gears match part numbers. However. for the 580, it shows the carrier as not being serviced, and no part number. On the 480C, it shows a complete replacement ring gear assy. kit, including the differential carrier (hub). Go figure.
Not sure if this will help, but did find a list of 580 CK's in salvage. As I've found in the past, if you have the serial number when searching for parts, is a big help. Case did a lot of part changes at certain serial number breaks.
Here's the link to more than several 580 CK's. They may possibly know what exactly was used in which model, and at what serial number break.
http://www.tractor-part.com/machines/dismantled?Make=case&Model=580CK
2013 CATERPILLAR TH514C TELESCOPIC FORKLIFT (A65053)
2013 CATERPILLAR...
CASE CX160D EXCAVATOR (A65053)
CASE CX160D...
2014 DODGE RAM HEAVY DUTY INSULATED BUCKET TRUCK (A63276)
2014 DODGE RAM...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
2016 Ford Taurus Sedan (A64194)
2016 Ford Taurus...
GYRO TRAC GT-25 FORESTRY MULCHER (A65053)
GYRO TRAC GT-25...
