58 MPG by 2032
   / 58 MPG by 2032 #411
I think you might have misunderstood something I said, I never said I rejected solar. I will not have a managed system though. Powerwall is $10k for 13.5kwh last I checked, which is absurd. Also tesla is booking 3+ years out for the tesla roof.
You are confusing Tesla Solar with Tesla Roof. The online quote for 10kW of Solar Edge inverters and optimizers is about $26k installed. Similar Tesla Roof is over $100k.
The first Powerwall costs more than N+1 because a Tesla Energy Gateway is needed to ensure one doesn’t out Powerwall power on the grid. Subsequent Powerwalls simply need to be plugged in.
The Solar Edge inverter is grid-tie, requires a 60 Hz pilot to sync. The Powerwalls provide that during an outage. Much of the Powerwall cost is the built-in inverter, charger, battery management, in each.
The management is all your own. Predictive weather is your choice to enable.
I have 38x 250w panels in the garage that I'm working on racking as we speak that I picked up for ~45/panel. I'm installing a hybrid inverter with 30kwh battery system. Currently looking at the eg4 13kw split phase inverter for $2700, and the eg4 rack mount 30kw LifePO4 system for $8300. The hybrid inverter will allow me to draw power from the grid in the event that my batteries get low.
I want a system that I manage, not someone else. It will not be connected to the internet. No one will be able to manage my power but me.
I suspect Tesla’s will not function without internet. But that also means you can monitor/control worldwide.
   / 58 MPG by 2032 #412
I'm not a fan of grid tied, for the reasons gone over previously in this thread. At first I was a fan, when people were using the grid like a battery. Analog meters that simply spun backwards, how good of a deal is that. Then there was smart meters, and billing differently backwards and forwards. Then the price they pay dropped. So if I use 6k during the day average at any given time, it makes zero sense for me to get a 12k or 18k system. Anything over 6k is like free electric for the power company because i'm getting virtually no credit for my off peak consumption.
The idea was you produce like crazy during the day running your meter backwards so at nighttime you can consume the extra you produce during the day, pulling it back from the grid. They've taken away the incentive to produce any more than you would at any one time during daylight hours.
Which is why I'm buying a hybrid system. So i can produce like crazy during the day, and instead of feeding it to the grid, feed it to my battery. Then I'll use my battery during the night. If my battery happens to fall a bit short in the wee morning hours, I'll pull from grid to supplement it.
And tesla's system you can probably monitor worldwide, but what's to say I can't do that with my system? I can remote into my home servers and control many aspects of my home, mostly security cameras. I have a web server that I can use to monitor the software via an API, or if it has it's own web server I can just forward the ports on my router to the inverter/bms and monitor it that way. If I can monitor it locally, I have a way to monitor it remotely.
   / 58 MPG by 2032 #413
When the neighbors found they had consistent surplus they bought A/C and switched out gas dryer and cooktop for electric… said it was better to use and not export
   / 58 MPG by 2032 #414
6k vs 6kW is getting fuzzy because your use during the day is not a flat line, and solar production is not a flat line. So you need something to buffer either battery or grid.
There is no longer an incentive because the utility was getting shafted.
Which is what I am also building for my new house.
Am not brave enough (yet) to buy enough batteries to go completely off-grid.
The big difference is Tesla has coders who love this stuff and so far are being allowed to express themselves (vs MBAs and market analysts designing systems). No server. No effort. No website (app only). The CPU is in the Tesla Energy Gateway. It knows how to talk to Solar Edge inverters, Powerwalls, Tesla Wall Connectors (EV charging), et al.
   / 58 MPG by 2032 #415
How many vehicles get 58 mpg now? Will electric vehicles somehow get factored into that. Between this new standard and all the standards on all the home appliances things will get expensive.
Yes they get averaged in. Most EVs get the equivalent of 100+ MPG.
   / 58 MPG by 2032 #416
That is the fictional EPA MPGe based on kWh.
I claim the honest metric is MPG$. The cost per mile of electricity vs gasoline or diesel. $ is the only honest measure of resource consumption. Scarce resources cost more to ensure they go to those who can make the most use of it. Labor is necessary for making the fuel. Capital investment. None of this is accounted for with kWh which is only a theoretical measure ignoring energy availability. Lots of energy in gasoline but only 30-40% is readily useable to convert to mechanical work.
My understanding is coal plants also operate at about 37% thermal efficiency. But coal is inexpensive and requires very little “refining”. Natural gas fired plants can reach 60%. Natural gas requires some refining. Am told the 3 pipes running through my property use at least one running south from fracking fields in Ohio to be processed in Texas, then much returns north on the other pipes to as far as Nova Scotia. And yet, I can’t get natural gas in the house I am building.
   / 58 MPG by 2032 #417
Squeezing more miles out of cars is difficult. Putting more junk on gas engines (like auto stop) will only put more vehicles in the scrap yards faster. (which pollutes more than the engine running).
   / 58 MPG by 2032 #419
I'm not sure what is worse engineering wise... GM's cylinder deactivation (that causes the engines to burn oil) or TPMS sensors or the stop start feature. All bad in my opinion.
Cylinder deactivation.
I love TPMS. I put aftermarket TPMS on my streetbike and on my trailers. Saved my butt many times on the streetbike providing early warning during a ride that the rear tire was deflating. Yamaha FJR1300 doesn't do bad things going straight until the tire is very deflated. I certainly do not want to enter a fast sharp turn with a half inflated tire as I'll occasionally drag a footpeg. I don't want to drag a handlebar.
I love TPMS so much I own an Autel TS-508. I know 5030 is really hating me now! The TS-508 is fun for being able to check tire pressure, non-contact. Don't have to bend over! Totally excessive! But fun! Impress Your Friends!
Neither my Tesla nor Subaru have TPMS PSI display. The lowly F-150 does. Tesla would add it for only $800, replace the TPMS module to the latest, update the software, and change the wheel sensors. Cool that they could/would do it, but not at that price.
The F-150 has ASS. Has an easy button on the dash to disable until the next engine start. Doesn't bother me most of the time but if I approach a traffic light that I think is about to change I hit the button. So far too lazy to fire up Forscan to turn it off by default. Doesn't bother me enough to make that effort and I don't know of anything I want to hack on the truck.
   / 58 MPG by 2032 #420
Show me a modern day engine that will go to 300k miles. Lots of 80's, 90's, and even early 00's engines make it well past 200k and with basic care, 300k. Adding complexity of all the crap they have added to increase mpg while maintaining power.
2015 Ford Fusion Hybrid Sedan (A56859)
2015 Ford Fusion...
2007 STERLING LT9500 MIXER TRUCK (A58214)
2007 STERLING...
2016 Peterbilt 389 T/A Wet Kit Sleeper Cab Truck Tractor (A55973)
2016 Peterbilt 389...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
Caterpillar 906M (A53317)
Caterpillar 906M...
2015 GENIE GS-4047 ELECTRIC SCISSOR LIFT (A52706)
2015 GENIE GS-4047...
