5740 top and tilt
   / 5740 top and tilt #1
VA MTN MAN
Virginia
kubota m5700
Installed my fit rite top and tilt today.everything fit just perfect, thanks Brian.
   / 5740 top and tilt #2
Thanks Ricky. I hope that you enjoy not having to get off the tractor to make those 3pt hitch adjustments. :thumbsup:
   / 5740 top and tilt #4
Looks real good. A TNT will be my next project!
Do you already have your rear remotes? You're more than half way there if you do. $530 + shipping for a complete "TnT" kit for your John Deere.
   / 5740 top and tilt #5
I have the power beyond kit but I don't think that will work. Maybe I'm wrong. :confused:
   / 5740 top and tilt #6
You have PB kit for what?
Do you mean you have the PB kit for your JD 3120 FEL valve?
   / 5740 top and tilt #7
Do you mean you have the PB kit for your FEL valve?
No, let me attach a pic. This pic was intended for the tread on the tire but it has the power beyond kit in the upper left corner.
I bought it off the lot and got about $3,500 off the list as it was a demo but you can see the power beyond kit, never used it though:confused:
   / 5740 top and tilt #8
Do you have a control lever for those QD's? Or are those QD's for something else?
I would get the factory John Deere set up if it were me. More $$$$ :(, but a lot cleaner installation. It is just about impossible to match the quality of the OEM factory designed remote setup in my opinion. Let me know once you have your remotes and I can get you setup. ;)
   / 5740 top and tilt #9
Be honest I really have no idea:eek:. I have a 5410 that I've always used the hydraulics on that for big projects but I would want to put a TnT on my 3120. I have only used the extra hydro on my 5410 so I really don't know about the power beyond on the 3120. There is one control lever that I guess could operate it but I couldn't tell you that for sure.:confused:
   / 5740 top and tilt #10
And I should add that I will more than likely be looking you up in springtime. Fixing my cabin up right now and have dropped about $7000 and haven't hardly started so right now isn't the best timing for something like this but I will have more use come springtime so I will be sure to look you up:thumbsup:
2021 JOHN DEERE 8R250 LOT NUMBER 193 (A53084)
2021 JOHN DEERE...
2014 Dodge Charger (A52377)
2014 Dodge Charger...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
2018 INTERNATIONAL LT625 SLEEPER TRUCK (INOPERABLE) (A52472)
2018 INTERNATIONAL...
2002 JOHN DEERE 450H CRAWLER DOZER (A51406)
2002 JOHN DEERE...
