5740 fuel filter
/ 5740 fuel filter #1
razor
Bronze Member
canada
Kubota L 6060(2), L 5740 (1)
I was going to clean the fuel filter bowl today. I shut off the fuel valve on the filter and started to remove the ring. I had a small container to catch the fuel but it seemed like the fuel would not stop flowing. I made sure that the valve was in the off postion, when I turned it back to the on postion it run faster so I had that right. I must have lost over 1 litre of diesel before I put the filter back together because I was scared of losing my whole tank of diesel.
It this normal too lose so much fuel in a filter change? When I change the fuel filter in the past I don't remember losing this much.
/ 5740 fuel filter #2
No should just lose what is above the housing, then it should stop. Sounds like your shut off isnt holding.
/ 5740 fuel filter #3
If your tank is full it is possible the fuel was running back through the return.
/ 5740 fuel filter #4
Yes, if the tank is full of diesel, it will come back down the self bleeding air line for the filter, if you notice there are three lines going to filter, two large and one small at the top.
David Kb7uns
/ 5740 fuel filter
Koboman and David were right. I drained a bit out of the tank and there were only a few drops when I changed the filter. Thanks for your help.
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
JOHN DEERE 8360R TRACTOR (A64278)
JOHN DEERE 8360R...
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
2023 Chevrolet Express 2500 Cargo Van (A61573)
2023 Chevrolet...
2025 International MV607 S/A 5/6 Yard Mason Dump Truck (A64194)
2025 International...
2021 CATERPILLAR 306CR EXCAVATOR (A65053)
2021 CATERPILLAR...
