5665 Gravely transaxle shim question
   / 5665 Gravely transaxle shim question #1
Ewcucchi
Gravely 12-G professional and Gravely 5665 Commercial
i had a leak from the right side transaxle. I removed 1 shim and it seems to have stopped leaking. Is there going to be a problem with gear alignment after removing a shim?
   / 5665 Gravely transaxle shim question #2
I am not sure, but the shims are used to set gear mesh. By now that machine probably has enough wear from normal use that it won't matter. Keep the oil level where it should be and I doubt you will have any problems. I do find it strange that the shim removal fixed a leak. Perhaps it had been apart before and the previous owner was not as diligent about cleanliness as you are. It probably wouldn't have leaked if you reassembled after cleaning.
Good job. Nice to hear success stories.
377789 (A51573)
377789 (A51573)
UNUSED GREAT BEAR 78" HEAVY GRASS FORK GRAPPLE (A51248)
UNUSED GREAT BEAR...
2020 JOHN DEERE 7R210 LOT IDENTIFIER 48 (A53084)
2020 JOHN DEERE...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
706075 LOT IDENTIFIER 77 (A53084)
706075 LOT...
