5600 falling off to one side
   / 5600 falling off to one side #1
rock3322
hutchinson, ks
toolcat plus many
Sorry guys can't find my old post but after everyones help i found the problem with the cat angled off to the drivers side whenever there is a load on the unit the problem was the rubber bumper missing from the front drivers side shock arm.
Thanks for your help you guys!!!
   / 5600 falling off to one side #2
Thanks for letting us know what it was. At least it was a simple problem.
DEWFPO
   / 5600 falling off to one side #3
where is this at on the shock? My dealer replaced my shock, cost me about $500 and it still leans. Was unable to see where the rubber stop is.. Appreciate your help!
   / 5600 falling off to one side #4
There's two rubber discs(snubbers) above each of the front springs.
DEWFPO
   / 5600 falling off to one side #5
Edit for my previous post : There are two rubber discs(snubbers) above the top of the front A-arms just outboard of where they attach to the center spine of the chassis.
DEWFPO
   / 5600 falling off to one side #6
I never followed up. Was missing a snubber (puck) on the driver's side. It was the one further in.. hard to see. Made a wood block to test.. and sure enough.. that was the problem.. After installing the wood block to test as a stop, I found the old stop had come loose and fallen further back in the arm. Will replace it soon but the wood is working great! :)
Can't believe the problem was that simple. Dealer didn't find that problem, the service manual doesn't show that part (at least I couldn't find it in there), and a piece of 2x6 cut to fit in that space made all the difference. It's like a new machine.
Now I just need to figure out if my axle is leaking or my power steering cylinder is leaking from inside the housing.. I imagine that repair will cost me but small price to pay for having a versatile little machine on the ranch.
2015 Toyota Prius Hybrid Sedan (A56859)
2015 Toyota Prius...
Kubota B2301 (A53317)
Central Machinery Horizontal/Vertical Bandsaw, S/N 366852447, 120 Volt (A59076)
Central Machinery...
LOT: (3) NEW Hi-Run 26 x 12.00-12 Lawn & Garden Tires (A59076)
LOT: (3) NEW...
2012 Ford Focus Sedan (A56859)
2012 Ford Focus...
2016 Chevrolet Silverado 2500 HD 4x4 Crew Cab Pickup Truck (A55973)
2016 Chevrolet...
