5570 4WD Issue
   / 5570 4WD Issue #1
MsBehave
Small-town, Arkansas
Mahindra 5570, Kubota L3000F
My 5570 isn't shifting into 4WD. All was working fine until it wasn't. I can pull handle no problem there. Linkage all the way to transfer case is moving ok...no problem there. No weird noises, etc. Neither Owner's nor Service Manual are much help. I always shift into/out of 4WD when I'm in neutral and at a complete stop. I did notice a turnbuckle for adjusting linkage, but don't wanna go tweaking stuff unnecessarily.
Any suggestions? I'm buffaloed
   / 5570 4WD Issue #2
Is the shaft going into the transmission turning as well as the linkage? Sometimes a roll pin falls out.
   / 5570 4WD Issue
Shaft is turning. And today when I had someone else check it out, they were able to manually rock the drive shaft and 4wd engaged. However, when in neutral, there was a distinct whine. Went away after a couple shifts on high/low shifter. 4wd also went away. I'm feeling more strongly now the turnbuckle needs to be adjusted allowing for a bit more rotation of the shaft in the side of the xfer case.
   / 5570 4WD Issue #4
Let's hope that's all it is. Otherwise it sounds internal.
2012 Hyundai Elantra Sedan (A50324)
2012 Hyundai...
Ideal Applegate 180 gal Water Trough (A50515)
Ideal Applegate...
(3) 8' High Pole Swinging Gates (A50515)
(3) 8' High Pole...
43002 (A51691)
43002 (A51691)
1992 Imperial Trailer (A50514)
1992 Imperial...
2004 Jeep Grand Cherokee SUV (A50324)
2004 Jeep Grand...
