555e need seals on hydraulic cylinder, main one on the backhoe
   / 555e need seals on hydraulic cylinder, main one on the backhoe #1
555enewholland
need to know any special ways to replace them or any specific way. or would it be better to take it to the shop. pretty sure i can do it if its pretty simple. anyone replace the seals on the backhoe cylinder have any problems or was it to hard or easy?
   / 555e need seals on hydraulic cylinder, main one on the backhoe #2
Welcome to TBN:D
Generally, re-sealing a cylinder is fairly easy. Boom cylinders on backhoes are a challenge because they are big and heavy, and the nut that hold the piston to the rod is often torqued at hundreds of ft/lbs.
If you post some pictures of the cylinder we can better advise how to get it apart, some have snap-rings, some have retaining wires, some have screwed on glands...just a lot of options.
   / 555e need seals on hydraulic cylinder, main one on the backhoe #3
Depending on the serial number of your machine and the part number of the cylinder, you may be looking at replacing the piston and gland if you want to use OEM parts. A good hydraulics shop may be able to match the seals used in your gland and piston if NH has obsoleted them. There is a lengthy service bulletin that gives pretty good info about this.
   / 555e need seals on hydraulic cylinder, main one on the backhoe #4
555eNH,
If you're going to DIY make sure you have a decent vise to be safe....the bolt (or nut-dependeing on which cyl) on the end of the rod is torqued pretty good...take apart and visit your dealer or hyd shop to match....the NH's cyls are metric sizes and prepackaged kits are the best way to go....they are pretty straight forward and make sure you loctite and torque back the same....Good Luck:)
2016 Ford Transit 250 Ambulance (A51692)
2016 Ford Transit...
2020 Can-Am Ryker Rally 900 Ace 3-Wheeled Motorcycle (A51694)
2020 Can-Am Ryker...
NPK GH15 HYDRAULIC HAMMER (A53843)
NPK GH15 HYDRAULIC...
2018 Black Diamond 3pt Hydraulic Log Splitter (A50123)
2018 Black Diamond...
2015 Dodge Charger Sedan (A51694)
2015 Dodge Charger...
2016 Isuzu NPR Landscape Dump Truck (A51691)
2016 Isuzu NPR...
