555DTC Alternator
   / 555DTC Alternator #1
dginter
Demossville, KY
05' Farmtrac 555 DTC
I'm looking to buy an alternator for my 555DTC, found one at Griggs Lawn & Tractor for $149.
was wondering if anyone has bought an alternator for theirs, where ya might of got it? or has anyone had dealings with Grigg's? on partsforfarmtrac.com they want $527
   / 555DTC Alternator #2
I would say grab the one for $149. Take your other one with you so you can look at the two together to make sure it will fit and the electrical connection is the same. I did the same with my New Holland once, worked great!!
   / 555DTC Alternator #3
Usually they can be rebuilt for not much money. We have a guy who usually does it for less than $100
   / 555DTC Alternator
was taking the battery terminals off to remove the alternator n noticed the wiring harness that runs along the underside of the hood had fallen from its support. it had fallen on the exhaust, peeled off the melted wire loom n noticed melted insulation on the wires, patched that all up n fired it up, she's fine... wire had shorted to ground... thanks for the help though!
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
TEST YOUR BID BUTTON! (A51243)
TEST YOUR BID...
2011 Ford F-250 Omaha Service Truck (A50323)
2011 Ford F-250...
UNUSED FUTURE MINI EXCAVATOR HEDGE CUTTER (A51244)
UNUSED FUTURE MINI...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
Bush Hog 2615 Rotary Cutter - INOPERABLE / PARTS ONLY (A52128)
Bush Hog 2615...
