Backhoe 555A Losing coolant
   / 555A Losing coolant #1
housemasters
My 555A Ford backhoe diesel loses about a gallon of coolant every 4-5 hours, but no leaks are evident. I notice what seems like a lot of moisture coming from the tube that comes out of the valve cover. May be some water in the oil also. Has anyone had this problem or know what it is?
   / 555A Losing coolant #2
Very good chance it has a blown head gasket, possibly cracked cylinder head or bad cylinder liner/o-rings if it's a wet sleeved engine.
Was the engine ever over heated??
   / 555A Losing coolant #3
Is coolant filling up the oil pan, or spilling on the ground, or is the engine making steam?
   / 555A Losing coolant #4
That's a lot of coolant to lose in not very much time. I'd think you could see it collecting somewhere, or smell it in the exhaust if it is getting in the combustion chambers.
Its making steam and coming out the valve cover tube.
   / 555A Losing coolant #6
You probably have a hole in a cylinder wall extending into the water jacket. That calls for a new or rebuilt block, or stripping, boring, and sleeving your block. In other words, a major overhaul.
   / 555A Losing coolant #7
check fan belt
2015 Nissan Altima Sedan (A54815)
2015 Nissan Altima...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2021 New Holland C327 Compact Track Loader (A57024)
2021 New Holland...
CLUB CAR (A55758)
CLUB CAR (A55758)
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2007 FORD F-150 XL TRITON (A55745)
2007 FORD F-150 XL...
