5530 trans dipstick location
   / 5530 trans dipstick location #1
blackcloud79
Saraland,Alabama
Mahindra 5530
1464458607176.jpgcan somebody tell me where the transmission level check is on here and where the add fluid hole is. Thanks
   / 5530 trans dipstick location #2
Got a photo from the back side? Not sure of your model, but just behind the seat, is usually the filler hole...
Ok i saw what was marked breather hole back there
1464462151316.jpgguessing this is the filler hole. Where do you check the level. I had a synchronizer line dripping and fixed it just wanna check and see how much ran out
   / 5530 trans dipstick location #5
See if there is a sight glass on the side of the transmission.... more common than dip stick... again not sure of your model. also, remove cap of breather... that might have a dip stick.
   / 5530 trans dipstick location #6
Look just under the clutch pedal for a long hex nut that's angled out of transmission case. It screws out and has a dipstick attached.
   / 5530 trans dipstick location #7
in the first pic, it is the long hex that has yellow painted on it.(that's the check point).
the breather in the back,(your secound pic ) is the the fill point.
nice looking tractor.
Ok thanks guys lol i kept looking at that hex nut earlier but i was like nah its gotta look like the oil dipstick.
Does tractor need to be running to check level my dipstick is dry
   / 5530 trans dipstick location #10
does not need to be running
The oil on mine is so clean,it is hard to see, I rub my finger along the dip stick to indicate where the oil level is.
I know you had a leak, so if there is nothing on the dip stick, you are low.
1992 Effer 7600 2S Knuckleboom (A51691)
1992 Effer 7600 2S...
Rogers 4th Axle (A51572)
Rogers 4th Axle...
2016 FORD F250 XL SUPER DUTY EXTENDED CAB TRUCK (A51247)
2016 FORD F250 XL...
2015 Ford F-250 Knapheide Service Truck (A51692)
2015 Ford F-250...
1999 Ford F-550 12FT. Flatbed Truck (A51692)
1999 Ford F-550...
Ford Pickup NR (A50323)
Ford Pickup NR...
