5530 Neutral Safety Switch
/ 5530 Neutral Safety Switch #1
AirForceIP
Brackettville, Tx
97 JD 770 FWD/Mahindra 5530 FWD
I've determined I have a neutral safety switch going bad on the speed shifter. I'm probably just blind, but I can't seem to find it anywhere. I have a service manual, but it's pretty useless. Anyone have an idea, or better yet, a picture of where that little bugger is at?
/ 5530 Neutral Safety Switch #2
There should be some sheet metal panels you can remove to expose the top of the transmision and the shifter housings. It appears there is a neutral safety switch with two wires mounted in one corner of what they call the rail housing assembly. This would be on the top of the transmission, a sort of square box maybe two or so inches tall with a tin cover bolted on top of it. At least that's what I see in the parts diagram.
Yes, it's in the shifter housing according to Bill's Tractor. Thanks for the input.
2016 FREIGHTLINER 125 DAYCAB ROAD TRACTOR (A65054)
2016 FREIGHTLINER...
6 1/4 INCH OD 90 DEGREE ELBOWS (A67714)
6 1/4 INCH OD 90...
2011 FORD F-250 SUPER DUTY (A67714)
2011 FORD F-250...
2025 JMR Stump Bucket Mini Skid Steer Attachment (A66734)
2025 JMR Stump...
2009 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2009 ALLMAND...
10ft S/A Utility Trailer (A66738)
10ft S/A Utility...
