553 562 563 673 H240 H260 H310 H340 H480 Loaders fits same JD mounting brackets
   / 553 562 563 673 H240 H260 H310 H340 H480 Loaders fits same JD mounting brackets #1
Brown Dog
North GA
John Deere 5115M 5101E H260 5115M 540M all MFD
I put my H260 Loader on my other tractor that had a 563 Loader on it & it works great.
The H260 is a Good bit stronger but also heavier than the 563.
My research shows 553 562 563 673 H240 H260 H310 H340 & H480 Loaders all fitting the same tractor brackets.
True Not all Tractors will be heavy enough to handle listed Loaders & hose lengths may not work, but they should fit the brackets.
The H260 Lower Brackets Angles UP :
The 563 Lower Brackets are Level :
Both upper loader mounting connections are in same location though.
   / 553 562 563 673 H240 H260 H310 H340 H480 Loaders fits same JD mounting brackets #3
Different angles might be do to different tractor models, or are these the same tractor model with just different loaders?
5093E & 5101E which is same exact tractors.
Maybe the leverage ratio reacts differently idk
   / 553 562 563 673 H240 H260 H310 H340 H480 Loaders fits same JD mounting brackets #5
Or an engineer figured out it took less metal to build the newer brackets and save $$ for Deere on each unit.
Sounds about Right :thumbsup:
The H260 is a Lot Heavier, Bigger Cylinders, Stronger & puts the bucket farther out front : so I'd think the Lighter & Shorter 563 would safely carry just as much weight :confused:
I run all 4 tires completely fluid filled for traction & ballast.
I use a 3pt lift type MX10 Cutter on hills w/o the loader.
The newer H260 Loader only lifts 6"'higher than the older 563
   / 553 562 563 673 H240 H260 H310 H340 H480 Loaders fits same JD mounting brackets #8
Has it been tested that 673 loader mounts will also fit a john deere H310? On the picture it shows the 673 mounts have what looks like a locking groove and the newer mounts do not have this?
I had a 553/563 loader & it fit my H240/H260 brackets fine.
I’m pretty sure the 673 is the same as 553/563.
My friend Sold his H310 loader because it was too long & heavy for his tractor.
His H260 fit perfectly :thumbsup:
The tab circled in you pic is only a guide for the lower pin when installing the loader.
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
2020 Nissan Pathfinder SUV (A51694)
2020 Nissan...
MONOSEM NG-3 LOT NUMBER 273 (A53084)
MONOSEM NG-3 LOT...
Electric Concrete Mixer (A51573)
Electric Concrete...
2022 Toro Workman 07921 Electric Utility Cart (A51694)
2022 Toro Workman...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
