5525 Hand Throttle Issue
/ 5525 Hand Throttle Issue #1
jremmons
Indiana
Deere 7210, Deere 6220, Deere 2750
Hello, we recently purchased a used Deere 5525 with Cab, FEL, and MFWD. The tractor runs great, but the hand throttle has two odd issues:
1) The throttle lever is very stiff
2) When you set the throttle lever and let off, it will move very slightly back towards idle (e.g. if you set it at 1500, it will drop back down to maybe 1300ish).
I know there is a nut near the lever that can be adjusted, I didn't know if that would fix these issues or not? It seems if you loosen the nut to make the lever less stiff, it would increase the issue of the lever falling back down towards idle? We've had issues with the throttle cable becoming slack on our 6220, but this seems a little different
/ 5525 Hand Throttle Issue #2
On my MF1540 tractor, the hand throttle lever has stayed stiff for the 12 or so years that I’ve had it; no drfit down at all.
I have a skidsteer though where the hand throttle has loosened and drifted down. The fix is to put a second nut on to hold the main nut in place once it’s tightened
