55 gallon drum sprayer
   / 55 gallon drum sprayer #1
DelfinoTX
Rio Grande Valley, Texas
Here are some pictures of a sprayer I made last year. Purchased the roller pump, regulator and spray wand at TSC.
The rest of the nylon fittings were purchased at my local harware store. I mainly use it to spray fence lines. I first used a Shureflo electric pump (you can see the base I mounted it too in the pic), but that wasn't powerful enough. The roller pump can produce up to 200 psi with the tractor idling! I usally spray at 125 psi.
I used high presure hose to connect to the roller pump with regular hose bib connectors. Very easy to find and no tools needed.
Made the cradle a little less wide than the drum for a snug fit.
Drum is secured by a single nylon strap.
Used two street ells with hose bib adapters for easy hookup.
The pump has "FLUSH WITH OIL AFTER USE" on it, so thats what I do. The caps keep the oil from draining out during storage.
   / 55 gallon drum sprayer #8
</font><font color="blue" class="small">( FLUSH WITH OIL AFTER USE )</font>
Yes sir, and if you store it with oil, or antifreeze, in it, it'll last for years. If not, it'll corrode and be hard to turn after awhile. That's a real nice looking setup you have.
   / 55 gallon drum sprayer #9
Excellent looking project.
I really appreciate you posting information about your sprayer. Im gonna try and make one just like that. It's exactly what I want. /forums/images/graemlins/smile.gif
dwight
2023 John Deere 8R410 MFWD Tractor (A53472)
2023 John Deere...
UNUSED FUTURE CG34 - 34" HYD CLAMP GRABBER (A51248)
UNUSED FUTURE CG34...
NEW Wolverine Skid Steer Trencher (A53002)
NEW Wolverine Skid...
New Wolverine Skid Steer Hydraulic Breaker (A53002)
New Wolverine Skid...
Flat Bottom Boat w/ Trailer (A51573)
Flat Bottom Boat...
2006 International 4300 Water Tanker Truck (A52384)
2006 International...
