Buying Advice 54D vs 60D besides 6", what is the difference
   / 54D vs 60D besides 6", what is the difference #1
tiger275
Knoxville, TN
Just wondering before I plunk down the money on a 1026r
   / 54D vs 60D besides 6", what is the difference #2
I went with the 54". I have only about 1/2 acre lawn now, and working my way out to about 1 1/2 acres. If I could do it over again, I would spend the $500 extra and get the 7-iron. It is a much tougher looking deck.
   / 54D vs 60D besides 6", what is the difference #3
I tried both, besides a bit of speedup the main differences are ease in edging and inner radius of cut. Having the edge be further out is nice in that you are a couple more inches away from that pesky low branch (ease in edging). The inner cut radius thing is the nicest part. Since you are a couple more inches out you can turn less sharply to go around a given tree, this means less lawn damage and a generally easier time. I hope that explanation makes sense. :)
So are you saying that only the 60 Is a"7 iron" deck? I didn't realize that.
   / 54D vs 60D besides 6", what is the difference #5
My suggestion before PLUNKING down any thing is go to the JD site and look at both. Then visit your local dealers, talk to a salesman and obtain a brochure. I think you will find a large amount of difference between the 54 and 60 inch deck for the 1026R.
   / 54D vs 60D besides 6", what is the difference #6
The 60d deck is a 7 iron deck meaning the housing is made from 7 gauge steel. The deck height above the rotating blades is higher meaning more air space which results in better air flow and a better mulching cut if you use the mulches kit. Besides that, the 60d costs more! I have the 60d as it was installed in error at no extra charge but the mulching kit for it cost me more than the 54 deck. I mulch and always have. The 60d is amazing for mulching.
Good luck choosing!
   / 54D vs 60D besides 6", what is the difference #7
I think they offer a 54d on zero turns, but the bigger mowers have a 54c 62c or a 60d.
   / 54D vs 60D besides 6", what is the difference #8
Another bummer about the 54D auto-connect for the all new one series is the "ventilation" of the top of the deck. There are no less than twenty holes of various shapes and sizes (round and square 6mm - 10mm). These hold all kinds of clippings and create places for the deck to clog. So PLEASE!!! get the 60D auto-connect "7-iron".
Xskier. That is great insight. My dealer only had the 60 in stock so not easy to compare.
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
2013 John Deere 310SK (A47384)
2013 John Deere...
1994 Chevy  2500 Dually Pick Up Truck (A50515)
1994 Chevy 2500...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2019 Ford F-150...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
John Deere 10 Shank Chisel Plow (A50515)
John Deere 10...
