545D starter/solenoid removal help
   / 545D starter/solenoid removal help #1
clydesdale
I am trying to replace the solenoid. Do I need to remove the starter? I am having difficulty getting to one of the back bolts of the solenoid. I went to remove the fuel filter and water seperator housing, to make room to pull the starter, but I do not know how to shut the fuel off. Does this housing need to be removed and if so, how do I shut the fuel off? I found a valve of some sort on a fuel line. But, it is on a hard line and another hard line is right next to it and they interfere with each other when I turn the valve. Is there a shut off on the pump itself? Thanks guys.
   / 545D starter/solenoid removal help #2
there should be a valve under neath the tank where the fuel line comes from the tank but u dont have to remove the filters are housing to remove the starter
You think I should be able to get it out without removing the filters? Do I have to remove the starter or can I remove just the solenoid? I have pics below. THANKS
   / 545D starter/solenoid removal help #4
Boy, they jammed the fuel filters right in there, probably for protection? I'd siphon the fuel from the tank and rig up a chute of some sort for the inevitable spill. I don't think you can remove the solenoid unless the starter is on the bench - you still can't reach the pin that pushes the fork. Having the fuel filters out gives you a good chance to clean everything, and you don't have much choice.
Jim
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
2012 KENWORTH T800(INOPERABLE) (A53843)
2012 KENWORTH...
2001 CATERPILLAR 140H VHP MOTORGRADER (A51406)
2001 CATERPILLAR...
2015 Dodge Charger Sedan (A51694)
2015 Dodge Charger...
2016 JOHN DEERE 700K LGP CRAWLER DOZER (A52705)
2016 JOHN DEERE...
2015 Chevrolet Tahoe SUV (A51694)
2015 Chevrolet...
