545A loader valve or pump ?
   / 545A loader valve or pump ? #1
dangtrucks
Wildomar
Ford 545A 4x4 skip
Hello .
I got this skip 2yrs ago the loader curl progressively getting worse. chatters wont lift with full bucket . changed all filters improved a little. Its not like I have any work for it but you never know. Tractor guy looked at it said he thought it was the splines on front pump for a grand he could fix it . i still think its loader valve bypass . is there any adjustments on those valves. Dan G.
   / 545A loader valve or pump ? #2
Have you put a gage on anything yet? Pump, valve , cy,. tested the relief, etc
No I got to get a manual for it . i just keep drivin it this way curl it in the pile then lift.dont think i have a gauge .low rpm it works kinda rev up it will stop curl
the pump is buried behind axle . whats the pressure at the pump suppose to be
I was hoping its o rings in the valve. tractor guy stopped by on his way to a job i got him gave me his two cents for free didnt chek pressure .
   / 545A loader valve or pump ? #4
Hello .
It does sound like a bad pump but without further test info ?????
Your guess is as good as mine.
P.S i live in Hemet not far from you
2013 Dodge Charger Sedan (A52377)
2013 Dodge Charger...
2012 Caterpillar 259B Compact Track Loader Skid Steer (A51691)
2012 Caterpillar...
2020 Terex RL4 Towable Light Tower (A51691)
2020 Terex RL4...
CAT Skid Steer (A50322)
CAT Skid Steer...
2005 IH 7600 t/a Dump Truck (A52384)
2005 IH 7600 t/a...
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
