545A loader valve or pump ?
/ 545A loader valve or pump ? #1
dangtrucks
Wildomar
Ford 545A 4x4 skip
Hello .
I got this skip 2yrs ago the loader curl progressively getting worse. chatters wont lift with full bucket . changed all filters improved a little. Its not like I have any work for it but you never know. Tractor guy looked at it said he thought it was the splines on front pump for a grand he could fix it . i still think its loader valve bypass . is there any adjustments on those valves. Dan G.
/ 545A loader valve or pump ? #2
Have you put a gage on anything yet? Pump, valve , cy,. tested the relief, etc
No I got to get a manual for it . i just keep drivin it this way curl it in the pile then lift.dont think i have a gauge .low rpm it works kinda rev up it will stop curl
the pump is buried behind axle . whats the pressure at the pump suppose to be
I was hoping its o rings in the valve. tractor guy stopped by on his way to a job i got him gave me his two cents for free didnt chek pressure .
/ 545A loader valve or pump ? #4
Hello .
It does sound like a bad pump but without further test info ?????
Your guess is as good as mine.
P.S i live in Hemet not far from you
2011 JOHN DEERE 672G MOTORGRADER (A63276)
2011 JOHN DEERE...
2022 CATERPILLAR 259D3 SKID STEER (A65053)
2022 CATERPILLAR...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
2013 Hitachi ZX160LC-5N Hydraulic Excavator (A64553)
2013 Hitachi...
2013 WINSTON AP22024AL-DC T/A 24FT TRAILER (A66091)
2013 WINSTON...
