5435 MF - do you need to recharge the accunulator...
   / 5435 MF - do you need to recharge the accunulator... #1
chade1968
5435 Massey Fergeson
after you change the transmission filters? The speedshift is not working after they where changed and I am trying to figure out why?
   / 5435 MF - do you need to recharge the accunulator... #2
Never charged the accumulator in mine. Done 3 or 4 filter & fluid changes.
Did you change the valve & it's still not working? Right filters were used? Did it happen right after the service? Did a wire get knocked off somewhere?
   / 5435 MF - do you need to recharge the accunulator... #3
Accumulator is there to reduce flow surges or dips. It should not cause a complete failure of the shift. I would do what MFRED suggested and start looking for loose connections.
Yea I changed the valve but it didn't change anything... There is power to the solenoid and I can hear the solenoid switch but it does not change the gear.
   / 5435 MF - do you need to recharge the accunulator... #5
It doesn't change real quick & change back does it? Mine will do that if the C/D switch gets water in it. There's a new switch with a rubber cover to fix. Mine's sitting on the toolbox somewhere for the next time.
I really think it's something simple if it was working before the service & not now. You did use the correct filters & fluids, right?
2013 Audi Q7 AWD SUV (A51694)
2013 Audi Q7 AWD...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2011 Ford F-150...
2011 Land Rover Range Rover Sport AWD SUV (A51694)
2011 Land Rover...
Sky Trak 10054 Legacy 10K Telehandler (A51573)
Sky Trak 10054...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
