5420 instrument cluster
/ 5420 instrument cluster #1
traded
NY
John Deere 1520; John Deere 5420
I'm having trouble with my instrument cluster and do not want to have to replace. The fuel gauge registers as either full or bounces when it gets to a 1/4 tank, the temp gauge pegs when working(replaced sensor) temp is in operating range, tested with a temp gun. Tachometer reads when lights are off, but when they are on it bounces all over the place. I'm hoping a possible ground issue, but I do not have a wiring diagram so diagnosing blindly. Is this a common occurrence, as John Deere and they suggested to replace the cluster.
/ 5420 instrument cluster #2
It does sound like ground issue. JD uses black wire color for ground. Also pins for the connector on the circuit board of the cluster may need resoldering, the solder joints can crack.
Thx, hopefully I can tackle it this weekend.
2019 Toyota Mirai Sedan (A61574)
2019 Toyota Mirai...
2010 PETERBILT 384 (A65643)
2010 PETERBILT 384...
Landhonor TP2-13-08D Skid Steer Mount Tree Puller  (A62679)
Landhonor...
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
2007 DRAGON 130BBL STEEL (A60736)
2007 DRAGON 130BBL...
2023 CATERPILLAR 289D3 SKID STEER (A62129)
2023 CATERPILLAR...
