540 PTO extension
   / 540 PTO extension #1
vangreenacres
John Deere 4010
My first post. Bought an acreage last fall and purchased a 4010 that has been great so far. Need info for two things on my 4010.
First: Went shredding Saturday and things worked just great until I bumped 'er into 2nd gear. About 15 minutes after doing so, I twisted my PTO extender (see photo). Where can I find another one of these? I googled "pto extender and get only a male/female ended part which I don't need. This is about 5.5 inches long and has a tightening bolt in one end to expand it into the PTO. Since I have a front-end loader there's an extra box on my PTO that makes this extender necessary.
Second: I noted on the gauge a line with "PTO." Does this line on a 4010 mean the Maximum for PTO use, or does it mean to "set your rpms here," when using the PTO for maximum torque." Have asked a half-dozen people over the age of 60 and I got a half-dozen different answers to this question.
Help with these two queries would sure be appreciated!
   / 540 PTO extension #2
Hi Vangreenacres. By gauge I assume you mean tachometer. The line marked "PTO" indicates the speed to which the engine must be revved to achieve the requisite RPM (usually 540 or 1000) at the PTO. I'm sure that someone will be along soon to help with the extender question. Good Luck.
   / 540 PTO extension
Thanks for this tip. I'll be sure to share it around, though I'm the only one around here with a 4010 anymore.
   / 540 PTO extension #5
vangreenacres
:welcome: to TBN
Would appreciate some pics of where this PTO extension is used. Looks to have been some serious torque to twist it like that..
When you kicked it into 2nd gear, do you suspect that overloaded the extension shaft?
What is the shredder brand/model?
   / 540 PTO extension #6
"Requisite" is the debatable part that probably leads to getting a 1/2 dozen different answers.
   / 540 PTO extension
Thanks for the input; will try to get some photos tonight or tomorrow along with shredder brand/model as you requestedpto 1.jpegpto 2.jpeg. Had the machine in 2nd gear for about 10 minutes and suspect the overload came when I hit some heavy thistles. I did not have the rpm's up to the "PTO" mark on the tach (as evidenced by my lack of knowledge as to what the line meant) but was close to it. What makes this extension unique (meaning I can't find it anywhere) is the bolt up the center that "expands) the open end to fit snugly into the PTO. See additional photo.
   / 540 PTO extension
Thanks for the input; will try to get some photos tonight or tomorrow. Had the machine in 2nd gear for about 10 minutes and suspect the overload came when I hit some heavy thistles. I did not have the rpm's up to the "PTO" mark on the tach (as evidenced by my lack of knowledge as to what the line meant) but was close to it. What makes this extension unique (meaning I can't find it anywhere) is the bolt up the center that "expands) the open
   / 540 PTO extension
   / 540 PTO extension #10
I believe that, that style of extension was used with the farmhand brand loaders when they used a pto pump for the loaders.
i have no clue where you could find one now.
Good luck
2015 Ram 3500 Enclosed Service Truck (A52377)
2015 Ram 3500...
2013 FORD F550 SHUTTLE BUS (A53426)
2013 FORD F550...
Michigan L-90 Wheel Loader (A52384)
Michigan L-90...
2007 50FT 3 CAR HAULER TRAILER (A53426)
2007 50FT 3 CAR...
Kubota ZG327 (A50120)
