54” MMM VS. 60”
   / 54” MMM VS. 60” #1
robertm
Northern Illinois
Kubota BX2660
Any thoughts on 54” over the 60” deck? Besides being able to get closer to weed beds with a 60” because it sticks out further, or getting through narrower openings with a 54”, am I missing any pros or cons of either? This would be on a B2601.
Thanks!
   / 54” MMM VS. 60” #2
The wider a rigid deck is, the more likely you are to scalp while mowing.
   / 54” MMM VS. 60” #3
I have the 60" deck on my B2601. It works great! No issues. But, I haven't mowed with a 54" so I can't compare it to the 60".
I can tell you mowing with the 60" deck is a lot faster than mowing with a 48" deck...
Mike
   / 54” MMM VS. 60” #5
I can't think of any reason to go with the 54 if you can get a 60 inch. I have 2 of them -- one on an older B2150 and one on a BX2200. Both excellent in my opinion. The difference is the older one on the B2150 is "ground following" while the one on the BX2200 is suspended. I think the ground follower does a slightly better clean cutting job. Especially on the 2601 go for the 60 inch. You will never regret it.
   / 54” MMM VS. 60” #6
Not sure how the orange ones are constructed, but I hit a mole hole on a slope and bent one of the gauge wheels. Once I straightened it back out, I added some reinforcement.
   / 54” MMM VS. 60” #7
Thanks!
I've had three 60 inch decks on my three different Kubotas. Besides the other responses......I found that they all just barely fit on the width of my equipment trailer (width wise)......but they did just fit. Never had any 54 inch MMM. The ground engaging (MMM) wheels on the B2650 are more robustly mounted than those on the suspended deck of the B2620
Cheers,
Mike
   / 54” MMM VS. 60” #8
Cheers,
Mike
Good point. I found the suspended deck wheels are much less strongly mounted than the ground following type. Ones on my daighter's BX2000 had to be reinforced and rewelded (mainly due to prior owner letting them rust.) And the trailer issue too -- I got a 6" wider trailer when I replaced the old trailer & that works great. My 60" deck on a BX2200 is just too tight to use on a 6ft wide trailer. It CAN be done depending on how the trailer is made and whether you added side boards to the trailer, etc. but really just too tight.
   / 54” MMM VS. 60”
I found two used B2601’s. One, a has a 54” deck, and the other has none. They are telling me the current model decks won’t fit these tractors. I suspect they only have interest in selling new, which they don’t have. Price will tell. I can’t think of anything that changed in the deck area after Swift-Tatch loaders were added to the B2601. They made it sound like they couldn’t order a deck for either B... which aren’t swift-tatch.
   / 54” MMM VS. 60” #10
I have a 60” for my BX. It’s a beast. I don’t know if the 54” is as heavy duty, but I would verify before buying. Frankly, I don’t know what the difference might be, between the deck for the BX vs the B.
2016 Chevrolet Cruze Sedan (A50324)
2016 Chevrolet...
1985 Chevy C8500 Altec D800 Digger Derrick Truck (A50323)
1985 Chevy C8500...
2017 Ford Fiesta Passenger Car (A51694)
2017 Ford Fiesta...
2014 Isuzu NPR-HD Landscaping Sprayer Truck (A50323)
2014 Isuzu NPR-HD...
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A52748)
Greenworks...
2013 Dodge Avenger Sedan (A50324)
2013 Dodge Avenger...
