5310 John Deere one way hydrolic attachment stop working
   / 5310 John Deere one way hydrolic attachment stop working #1
QAJ27
Wesson,ms
John Deere 5310
When I plug in my one way cylinder to my remote on back of tractor it works until tractor get up to working temp and it's like it locks up. I have to plug a two way into that remote and it unlocks. This system remotes are run by the joy stick and I don't believe the value is opening up to float position. What could be the problem. When I push joystick forward I hear tractor load up verses the fluid just flowing out of oneway cylinder. Help!
   / 5310 John Deere one way hydrolic attachment stop working #2
If you have QD's on the remote valve the work ports are blocked from use the valve will go into relief.
If you plug a SA cyl into a DA valves work port A, the fluid is blocked from work port B.
In order to let the fluid out of work port A, the valve must go into relief using work port B, then the fluid will exit out of work port A.
Normally when using a SA cyl on a DA valve, you have to plug the other work port. If you have QD's that function is satisfied.
The other way to use a SA cyl on a DA valve is to run a hose from the other work port to tank, and that will let the fluid exit the cyl.
Did you say you have float on the remote valve.
If so , you could use the float mode to let the cyl retract as all ports are open to tank.
To use float on a DA valve and a SA cyl in work port A. you have to snap it into float quickly or it will go into relief.
So it really depends on how you have it set up.
I am not understanding how the valve works when cold and not hot when using only one work port.
The valve should go into relief with a closed QD on the other work port. The fluid should enter and exit the same work port unless you run the B work port to tank..
You might try this.. Make up a hose to plug into the B work port QD and run the other end of the hose to tank or another return hose.
If you are using B port to feed the cyl, then to retract the SA cyl, you should go into float. When fully retracted, then snap it back to neutral.
I think I figured it out! The float on my joy stick isn't working. When I push is all the way forward it doesn't float it tries to add down pressure. How do I fix the float on the joystick?
   / 5310 John Deere one way hydrolic attachment stop working #4
Remove the can on the bottom of the valve spool with float and inspect, clean and relube and put back together.
There are little balls and springs in a sleeve that lock the spool in float detent. , so be careful.
You might keep a magnet close by.
When working correctly, the float spool should snap in place and stay there until you pull the lever back to neutral.
There are drain holes in the can, so make sure the holes are down so any moisture can escape.
Here is some hyd data you may or not know.
Hydraulics: JD5310
Type: open center
Pressure: 2855 psi [196.9 bar]
Valves: 5
Pump flow: 11.4 gpm [43.1 lpm]
Total flow: 18.2 gpm [68.9 lpm]
Steering flow: 6.8 gpm [25.7 lpm]
Steering press.: 1955 psi [134.8 bar]
   / 5310 John Deere one way hydrolic attachment stop working #5
Here's the parts schematic if it has the factory valve.
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
UNUSED IRANCH IRMC HIGH END ELECTRIC MASSAGE CHAIR (A54757)
UNUSED IRANCH IRMC...
(49) 2" X 3" X 27" TUBING (A54756)
(49) 2" X 3" X 27"...
1998 JCB 930 ROUGH TERRAIN FORKLIFT (A52705)
1998 JCB 930 ROUGH...
2019 JOHN DEERE 245G LC EXCAVATOR (A52705)
2019 JOHN DEERE...
