5264 D won't start, safety switch locations.
   / 5264 D won't start, safety switch locations. #1
Mlawson
Shut it off and when I went to start it again it won't start. I have checked all the connections all the lights work and come on but when you go to start it - nothing. New battery already and is good, connections there are clean so the only think I can think of is the brake safety switch but I have no idea of the location - anyone know where it is? Any other ideas that it might be? Seat safety switch? Is there any other safety switches? This tractor has driven me crazy. Had the **** drive shaft come off last week which broke a hydro hose, the whole tranny rebuild issue and now this- be ready to get rid of this tractor soon. Thanks for any recommendations.
   / 5264 D won't start, safety switch locations. #2
Check to make sure the PTO switch isn't on. Brake pedal switch - sometimes requires extra force to make contact. Or check under seat for that switch continuity. Should be one of the 3.....
Seat switch and PTO switch are good so thinking is the brake switch- any idea where it's located?
   / 5264 D won't start, safety switch locations. #4
If you follow the linkage, I think it's nder the center tunnel with a button or clip. I know some of the 5000's I've owned you have to really press the brake pedal, where the tab is bent a bit. Shoudn't be too hard to find....
Found it and when my hydraulic hose broke it must have moved the switch just enough that it wasn't making good contact.
2014 VOLVO VNL (A55745)
2014 VOLVO VNL...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A58018)
2019 INTERNATIONAL...
2020 DRAGON ESP...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2019 GALYEAN 150BBL STEEL (A58214)
2019 GALYEAN...
2015 International Durastar 4300 SBA 4 x 2 Water Truck, VIN: 3HAMMMMN4FL510006, Cummins Turbo Die... (A59076)
2015 International...
