Oil & Fuel 5252 starved for fuel?
   / 5252 starved for fuel?
I'm sorta back to where I started, except I did rule out an electrical problem. The last mowing, the spark indicators were indicating good spark on both cylinders when it stalled out
When I replaced the fuel filter, I used a generic automotive filter because my Cub dealer didn't have one in stock. So I think I'll pull the deck again and start back at the tank. I think it's just not getting enough fuel at full RPM with the deck engaged.
Curt
Well, I had some time today to try a few more solutions.
I removed the fuel filter and drained the tank into a can, I had plenty of flow and no obvious debris in the line.
I replaced the fuel filter with the right filter, it had to be ordered, the automotive filter was a clear case and had a bit of debris in it.
I split the carb and removed the top half and float, blew everthing out and re-assembled.
And just on the outside chance that this is a valve sticking when it heats up, I did a thorough cleaning with the air hose of all the engine parts.
Then I mowed for two hours with no symptoms. I'm still not sure it's fixed!
Then I discovered I have a huge grub problem, I was thinking the brown patches were due to lack of water but I noticed a lot of skunk diggings in the yard and when I examined one of the brown patches, it pulled up like a carpet, just like I've read about.
Dang, it's always something!
Curt
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
2014 Freightliner 108SD Crane Truck, VIN # 1FVHG5CY3EHFL1495 (A57453)
2014 Freightliner...
2013 Case-IH 160 Puma (A57148)
2013 Case-IH 160...
2018 Nissan Titan 4x4 Crew Cab Pickup Truck (A56858)
2018 Nissan Titan...
2012 John Deere 7230 131HP 4WD Agricultural Utility Tractor (A56857)
2012 John Deere...
2019 WABASH DVLSHPC 53FT DRY VAN TRAILER (A59575)
2019 WABASH...
