5230 case tractor rpm surge
   / 5230 case tractor rpm surge #1
impala
hello everybody i have a 5230 case and the rpm surges from 150 rpm down any help would be greatly appreciated thank you very much
   / 5230 case tractor rpm surge #2
Are your figures correct as cranking speed for engine would be around 300 rpm's. ??? low idle around 800 rpm ????
Or are you talking PTO rpm,s
Need engine rpm's to make a proper judgement ?????
engine rpms drop about 150 rpm and when driving they drop range from 1000-2500 rpm any help greatly appreciated
   / 5230 case tractor rpm surge #4
sounds like your getting air into fuel system these units have a problem with the fuel hoses coming out of the tank,first check the hose right at the little in line fuel filter for cracking if it looks old you might have to replace,to test the problem you could try putting a hose into tank and hooking it to your fuel system and see if problem goes away.
   / 5230 case tractor rpm surge #5
Ditto that, but first be certain the filter isn't plugged.
   / 5230 case tractor rpm surge #6
thats right air ingression usually causes rpm surges,if those are your symptoms air is likely getting in somewhere.Do you have difficulty starting it?
the tractor starts good but idling and driving the rpm changes about 150 rpms
   / 5230 case tractor rpm surge #9
have you tried fuel filters yet is there any fuel leaks anywhere,to determine if its mechanical is it a consistant surge,does the linkage on the fuel pump move back and forth in unison with rpm changes
   / 5230 case tractor rpm surge #10
I'd start with new fuel filters as well as checking the air filter.
2018 WACKER NEUSON RTSC3 ROLLER (A53426)
2018 WACKER NEUSON...
2,500lb Traveller ATV Winch (A51573)
2,500lb Traveller...
2021 Ram 1500 Bighorn (A53472)
2021 Ram 1500...
2013 ISUZU NRR 20FT FLATBED TRUCK (A52576)
2013 ISUZU NRR...
CASE 580 SUPER N BACKHOE (A51246)
CASE 580 SUPER N...
Mccormick Hammer Mill (A51573)
Mccormick Hammer...
