5220 won’t start, no crank, no lights
   / 5220 won’t start, no crank, no lights #1
RobinLynn
John Deere 5220
I have a JD5220 that almost started tried again and won’t start, no crank, battery good, all battery connections clean, no dashboard lights. What could it be and how do I check from here?
   / 5220 won’t start, no crank, no lights #2
First thing to check would be if it has any fusible links coming from the battery that might have burned out; next would be the fuse panel to see if it has a master fuse that went.
   / 5220 won’t start, no crank, no lights #3
Did you load test the battery?
Welcome to TBN
   / 5220 won’t start, no crank, no lights #4
There are fuses to check. I have the 5520 which is similar. I've got the cab version and if you have the open station fuses will be in a different location. But on mine they're under the left console and under the center steering wheel pedistal.
   / 5220 won’t start, no crank, no lights #5
Ditto on load testing or at minimum check voltage of battery
2024 HURRICANE GF480 - 48" ROTARY DRUM SCREEN (A52706)
2024 HURRICANE...
Sterling AT (A55301)
2003 Big Tex 10PI...
2016 Freightliner M2 106 Altec AM50 Insulated Material Handling Bucket Truck (A55852)
2016 Freightliner...
BUSH HOG 2615 - 15' BATWING MOWER (A51243)
BUSH HOG 2615 -...
2025 Swict 66in Bucket Skid Steer Attachment (A53421)
2025 Swict 66in...
