5220 won’t start, no crank, no lights
   / 5220 won’t start, no crank, no lights #1
RobinLynn
John Deere 5220
I have a JD5220 that almost started tried again and won’t start, no crank, battery good, all battery connections clean, no dashboard lights. What could it be and how do I check from here?
   / 5220 won’t start, no crank, no lights #2
First thing to check would be if it has any fusible links coming from the battery that might have burned out; next would be the fuse panel to see if it has a master fuse that went.
   / 5220 won’t start, no crank, no lights #3
Did you load test the battery?
Welcome to TBN
   / 5220 won’t start, no crank, no lights #4
There are fuses to check. I have the 5520 which is similar. I've got the cab version and if you have the open station fuses will be in a different location. But on mine they're under the left console and under the center steering wheel pedistal.
   / 5220 won’t start, no crank, no lights #5
Ditto on load testing or at minimum check voltage of battery
2013 International WorkStar 7400 Altec AM547 50ft. Bucket Truck (A55852)
2013 International...
WB 36" PIN ON DITCHER BUCKET (A52707)
WB 36" PIN ON...
2020 CATERPILLAR 259D3 SKID STEER (A52705)
2020 CATERPILLAR...
Ammco Brake Machine (A53424)
Ammco Brake...
Informational Lot - Financing (A55314)
Informational Lot...
