5205 3ph lift arms
/ 5205 3ph lift arms #1
bobbyjak
Bronze Member
Oakwood, TX 75855
JD 5205 4wd
Received tractor last Friday..The 3ph lift arms will not go all the way down to the ground as they did on my Case 1390..Lacks about a foot touching the ground..
Is this normal?..
/ 5205 3ph lift arms #2
I'm curious as to why would you want them to touch the ground?
Have you adjusted the lift linkages to the lowest position? I adjusted mine to about 8" from the ground which works fine for me. I guess you could adjust them till they touch the ground, I've just never seen it done before.
/ 5205 3ph lift arms #3
My 790's lower links arms drop to about 6"-8" above the ground.
I've looked at a lot of the Deere CUT's...all the ones I've seen were about the same...
/ 5205 3ph lift arms #4
Out of the 4 John Deeres I have owned , I have never had 1 that the arms went any closer than 6" to the ground.
Jim
What do you mean by "lift linkages"?..I moved the stablizer chains to lowest position along with top link..Mine is a minimum of 12" from the ground..I think they should be 4"-6" from the ground..
/ 5205 3ph lift arms #6
Congrats on the new tractor.
The "lift linkages" are the links that go between the arms and the rocker arms that "lift" the arms. On one side, the lift linkage has an adjustment on it to change the 'level' of the two arms with respect to each other. The sway chains or links just restrict the swing motion of the arms sideways.
Again, the question - why do you want to go below the 12"?
Lower just restricts the height they can raise to, as I look at it.
I have some home made 3pt hitch's where the lift pins are very low..I guess I could move them, but it would be much easier to do it at the tractor end..It's no big deal, was just wondering if this was normal for a Deere..Spoil with Case I had for 22 yrs..Thanks
/ 5205 3ph lift arms #8
</font><font color="blue" class="small">( this was normal for a Deere )</font>
Probably normal with the size tractor you bought /forums/images/graemlins/wink.gif
Can you lengthen the 'lift' links as suggested? Is it Cat I ?
What attachments have the lift pins so low? Just curious, and pics would be nice. /forums/images/graemlins/wink.gif
/ 5205 3ph lift arms #9
On pages 55-1 through 55-16 of your operators manual is a lot of information on the rockshaft and 3-point hitch. I lowered mine to where I did not have prop up my box scrape up to attach it.
Did you get the telescoping draft arms with your tractor?
Thanks for the info..Slowly reading the owners manual..I did get the telescoping arms..Haven't attached anything yet..I am a little disappointed that I can not shift on the go even though I depress the clutch..You can hear/feel the gears grind some..Do you have the same problem?..From reading the FEL owners manual & looking at labels on lift cylinders, I found that the dealer installed the lift arms in the wrong pin holes..It allows the FEL to lift to high creating an unsafe condition..Dealer coming out to correct problem..Is yours connected in proper holes?..I have the 522 JD loader..
/ 5205 3ph lift arms #11
The 5205 has a sync-reverser, but it was not designed to shift on the fly. Your dealer should have explained that to you. It would be nice to shift on the fly, but that has not hindered me an any way doing the work I want to do. It's great for loader work, which I do a lot of. The more you operate your tractor the more you will like it.
The 522 loader does have particular pin connections specifically for the 5105/5205. The 522 is a super strong loader and will lift the back of the tractor off the ground before you know it! It will lift even more if the pins are not in the correct holes. Good thing you caught that.
Go ahead and attach something and get busy using that machine! It was built to work so hook up a box scrape or bushhog and drag some dirt around or run over some small trees. /forums/images/graemlins/grin.gif Get a tooth bar for your loader if you are going to be digging, etc. Makes a big difference.
BTW - We're still waiting on the pictures! /forums/images/graemlins/cool.gif
New/Unused Wolverine 84in Snow Pusher (A65583)
New/Unused...
2019 DODGE RAM 1500 (A65643)
2019 DODGE RAM...
Manure spreader for sale / Excellent Condition / Make offer
Manure spreader...
2006 Ford F-350 12ft. Flatbed Truck (A61573)
2006 Ford F-350...
3'x8' Stack of Sheet Metal (A64127)
3'x8' Stack of...
Set of Helicopter Saddle Tanks (A64126)
Set of Helicopter...
