52 8n problems
   / 52 8n problems #1
52 8n
pennsylvania
ford 8n
hello, I have a 1952 8n ford my grandfather gave to me.he bought it at a sale and brought it home and put new rings in it because it hat 8 rings squeezed on I piston:thumbdown: from a p.o. but no matter what it will not fire on no. 2 cylinder after it warms up idiling.it runs great hen first started but after that it wonte fire till about 1000 rpm I thought it had a cracked block cause it looks like mayonnaise on the oil fill cap but it donte use any antifreeze ive ran out of ideas other than it needs a new cylinder or valve work and it starts super easy even on 6v.
   / 52 8n problems #2
do a compression test, dry, then wet.
see if # 2 has much compression...
check distribuitor shaft for play.. play can cause eratic points gap.
lastly. have you replace dthe plug and wire on #2 and the cap, or at least checked it for arc scoring, tracks or cracks?
M & M Grain Drill (A50515)
M & M Grain Drill...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50324)
2018 Toro Grounds...
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A52128)
2-Row Peanut...
2023 New Holland Workmaster 25S Compact Tractor - Only 65 Hours (A52128)
2023 New Holland...
