52 8n oil filter fittings
   / 52 8n oil filter fittings #1
vwbusman66
Kingsville, MD
1952 Ford 8N
So I decided to change the oil and filter yesterday on the 8n in preparation for winter. I disconnected the lines from the filter so I could drain it and during re-assembly, I split the brass fitting. I ran to the auto parts store and TISCO and neither had a brass fitting. So I bought a piece of brake line to make a new line to eliminate the fitting all together- I stripped out the canister. I have located a new (used) canister with a drain plug. What is the correct description for the 2 brass fittings for the stock canister? 1/8 male to 7/16-24 female ?
Has anyone had any experience with this spin on adapter: 8N Ford Tractor spin on oil filter adapter NEW!
   / 52 8n oil filter fittings #2
I think you need steel line inverted flare to 1/8 pipe fitting (I am not positive though). I had not seen that adapter before but I will be buying one for our NAA. Remember this is a bypass filter not a full flow filter.
   / 52 8n oil filter fittings #3
Forget the adapters, fix the OEM setup. Its made it how many decades? And your going to drastically improve it? ;)
4' X 2' X 1' HIGH METAL STORAGE BOXES (A51248)
4' X 2' X 1' HIGH...
UNUSED FUTURE 32" HYD TILTING BUCKET (A51248)
UNUSED FUTURE 32"...
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
JOHN DEERE 3032E TRACTOR (A51247)
JOHN DEERE 3032E...
RIDE AND DRIVE INFO (A50775)
RIDE AND DRIVE...
2000 Freightliner FL70, 5.9 Cummins (A52384)
2000 Freightliner...
