52 8N Generator
   / 52 8N Generator #1
vwbusman66
Kingsville, MD
1952 Ford 8N
Hi all, I am located in southern Maryland and was wondering if anyone knows of someone in the U.S. who can rebuild my generator to operating condition. Any help is apreciated. Regards, James
   / 52 8N Generator #2
I'm not in your area.. but hit your phone book and look for alternator / starter shops in your local.. many of those rebuild gennies. Also electric motor places.. etc.
If it can't be rebuilt.. you can still get repops.
First. are you sure the genny is bad?
have you motor tested it and full field tested it?
Don't forget the reg and wireing too.
PS.. welcome to TBN.
   / 52 8N Generator
Just found about five local guys who could rebulid it. It wont motor. not sure how to field test. Thanks, Ive read alot of your replies and hope you would be the first to reply. I have totally rewired this tractor plus a new regulator. Starts and runs well, just doesnt charge. Regards, James
   / 52 8N Generator #4
if it won't motor then you needent worry about a full filed test.
It has a hard fault.. like field or armature or brushes/brushholders that will need to be addressed first.
once you get it back and installed.
jump bat hot to armature with a jumper wire to polarize it and you should be good to go if the reg and wireing is good.
   / 52 8N Generator
Okay, took it apart and discovered that the wire running from a field to the field stud is cut, so now it is too short to re wire. Any ideas of how to fix this? already coarse emery clothed the armiture and fine emery clothed the commutator. I cant get the bolt for the field stud off beacue it seems to be some kind of a carrige bolt with a long, plastic insulator. I probably will gind it off with my dremel, but will need a replacement. Any ideas, Regards, James
   / 52 8N Generator
just got new hardware and have it all crmped greased... next, well polarize and see if itll motor
   / 52 8N Generator #7
the broke wire, if not shorted to ground coul be crimp connected or soldered. field circuit current is low amps.. just a few..
JOHN DEERE 1705/6700 (A53084)
JOHN DEERE...
2014 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A51246)
2014 CATERPILLAR...
2001 INTERNATIONAL 2574 6X4 DUMP TRUCK (A51406)
2001 INTERNATIONAL...
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
2024 KMC 7406 LOT NUMBER 11 (A53084)
2024 KMC 7406 LOT...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
