Okay, took it apart and discovered that the wire running from a field to the field stud is cut, so now it is too short to re wire. Any ideas of how to fix this? already coarse emery clothed the armiture and fine emery clothed the commutator. I cant get the bolt for the field stud off beacue it seems to be some kind of a carrige bolt with a long, plastic insulator. I probably will gind it off with my dremel, but will need a replacement. Any ideas, Regards, James
