Darth_DMack
Platinum Member
Just resting.. watching the burn pile. This tractor puts in the work!!!
do you need curb feelers?Working the grapple, I noticed a few of the quick connect fittings on the W.R. Long fitting block (not sure what to call it) were leaking.
I shut the tractor down, relieved the hydraulic pressure, and cleaned each of the fittings (used brake cleaner to spray them out) and re-installed.
No more leaks. I also made sure to tighten the AN fittings while I was at it.
I guess that this needs to be watched more closely. This is my first tractor, so I am learning as I go.
42 hours and some change so far, zero issues.
I did bend the steps on a tree stump working in close quarters. So, I need to figure out how to order replacement parts. Other than that, this tractor has been flawless.
LOL... that made me chuckle.do you need curb feelers?
