5155 putting in work…
   / 5155 putting in work… #1
Darth_DMack
South Carolina
2023 Mahindra 5155
Just resting.. watching the burn pile. This tractor puts in the work!!!
   / 5155 putting in work… #2
Looks good! My 5005 put in some work today too.
   / 5155 putting in work… #3
Got more work in yesterday. Used the new (to me) 5005 and ML214 loader to move a few tons of rock to a sink hole, dug a few huge ones from the ground, and popped out a few walnut stumps from the old farm garden. Used a subsoiler on the stumps first and the loader. Lots of power from the tractor and loader.
Working the grapple, I noticed a few of the quick connect fittings on the W.R. Long fitting block (not sure what to call it) were leaking.
I shut the tractor down, relieved the hydraulic pressure, and cleaned each of the fittings (used brake cleaner to spray them out) and re-installed.
No more leaks. I also made sure to tighten the AN fittings while I was at it.
I guess that this needs to be watched more closely. This is my first tractor, so I am learning as I go.
42 hours and some change so far, zero issues.
I did bend the steps on a tree stump working in close quarters. So, I need to figure out how to order replacement parts. Other than that, this tractor has been flawless.
   / 5155 putting in work… #5
do you need curb feelers?
LOL... that made me chuckle.
Actually, it was such a NEWB mistake... granted, first tractor, learning how to use the grapple, I think I only had 3 hours on it at the time.
I was removing black gum trees, and had cut the tree (4" diameter) about waist high, so I could pull it up using the chain / tire method.
I had forgotten about said stump, and BAM!!!! Turned right into it, not paying attention. My steps took the direct hit.
No damage to the tractor other than that, but my ego was bruised.
Curb / Stump feelers are in order now... :)
Adams 5T HC Spreader (A55301)
Adams 5T HC...
2008 WABASH 53FT REEFER TRAILER (A56138)
2008 WABASH 53FT...
2019 Ram 1500 4x4 Crew Cab Pickup Truck (A55852)
2019 Ram 1500 4x4...
202479 (A54757)
202479 (A54757)
We Don't Dial 911 Wall Art (A55853)
We Don't Dial 911...
PALLET OF (2) HONDA GENERATORS (A55745)
PALLET OF (2)...
