5145 inaccurate RPM after warm up
   / 5145 inaccurate RPM after warm up #11
As I understand it, the 5145 has a four cylinder engine, it should be as smooth as butter. If it is rough from contaminants in the fuel that is one thing, but otherwise, I would see this as an issue for warranty.
   / 5145 inaccurate RPM after warm up #12
correct smooth as butter as i recall, just gets louder as the rpms go up, i will check mine tonight to see if i can detect anything at that rpm.
on a side note, in the older equipment the tach was run off of a signal from the alternator to sense alternator rpms and deducing engine rpms from that, the 5145 uses a common rail injection system which involves a crank sensor and computer to calculate fueling and therefore "knows" the rpms. The rpm signal is transmitted via digital signal from the computer to the cluster. The bottom line is that cleaning the analog wiring from the alt will not affect this rpm gage.
the 5145 has an ODBII connector under the seat BTW, mine has a cover that was lose when i recieved it, it is best to put the cover back on to keep water and stuff out of it.
  • instriment cluster.pdf
   / 5145 inaccurate RPM after warm up #13
Thanks for noting the differences in the way the tach is driven in the 5145 as compared to my older 4035.
2019 JLG ECOLIFT 70 SELF PROPELLED MANLIFT (A51242)
2019 JLG ECOLIFT...
LONG 445 TRACTOR (A51243)
LONG 445 TRACTOR...
UNUSED JCT SKID STEER QUCK ATTACH 72" BRUSH CUTTER (A51244)
UNUSED JCT SKID...
2010 ATLAS COPCO PORTABLE AIR COMPRESSOR (A51244)
2010 ATLAS COPCO...
43009 (A51691)
43009 (A51691)
2006 MACK CV (GRANITE) BOB TAIL KILL TRUCK (A50854)
2006 MACK CV...
