5145 inaccurate RPM after warm up
   / 5145 inaccurate RPM after warm up #11
As I understand it, the 5145 has a four cylinder engine, it should be as smooth as butter. If it is rough from contaminants in the fuel that is one thing, but otherwise, I would see this as an issue for warranty.
   / 5145 inaccurate RPM after warm up #12
correct smooth as butter as i recall, just gets louder as the rpms go up, i will check mine tonight to see if i can detect anything at that rpm.
on a side note, in the older equipment the tach was run off of a signal from the alternator to sense alternator rpms and deducing engine rpms from that, the 5145 uses a common rail injection system which involves a crank sensor and computer to calculate fueling and therefore "knows" the rpms. The rpm signal is transmitted via digital signal from the computer to the cluster. The bottom line is that cleaning the analog wiring from the alt will not affect this rpm gage.
the 5145 has an ODBII connector under the seat BTW, mine has a cover that was lose when i recieved it, it is best to put the cover back on to keep water and stuff out of it.
  • instriment cluster.pdf
   / 5145 inaccurate RPM after warm up #13
Thanks for noting the differences in the way the tach is driven in the 5145 as compared to my older 4035.
2012 Ford Transit Connect Van, VIN # NM0LS7DN0CT092703 (A54865)
2012 Ford Transit...
Kivel Pallet Forks (A53316)
Kivel Pallet Forks...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
New JMR Skidloader Stump Bucket (A50775)
New JMR Skidloader...
2015 FORD E350 16FT BOX TRUCK (A54607)
2015 FORD E350...
2006 JLG 2030ES 20ft Electric Scissor Lift (A55851)
2006 JLG 2030ES...
