5145 Hydraulics speed
/ 5145 Hydraulics speed #11
Hello BreakerFixer, After operating commercial grade hydraulics, the home owner grade are a step down as they as only adequately sized. You are stuck with what you have.
For future reference,
:look at the hydraulics spec: type, ie closed centre(can lift AND curl to keep bucket level MANUALLY), open centre is 1 or the other, not both.
: pump FLOW, (note, some tractor have 2 pumps for specific jobs,ie power steering is separate from scv, 3ph and loader hydraulics.) Result: the total flow sounds good until you subtract the power steering etc and suddenly the loader/scv turns out average. Flow to loader and scv are what count(high demand). 3ph demand is low.
Also you would want 2scv minimum, 3 or 4 is better to future proof. It is much cheaper to get scv and 3rd service up front than retro fit.
Good Luck
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
Case-IH 370 Steiger (A57148)
Case-IH 370...
Giyi GY-TB47 Forklift Telescopic Boom (A60463)
Giyi GY-TB47...
18' Field Cultivator (A60462)
18' Field...
UNKNOWN  SPOOL TRAILER (A58216)
UNKNOWN SPOOL...
2014 KEYSTONE COUGAR CAMPER (A60736)
2014 KEYSTONE...
