511 Backhoe - No Float Position?
/ 511 Backhoe - No Float Position? #1
Farmerboy
Parker, Pennsylvania
Mahindra 85 / Ventrac 4500P
I've got about an hour of operation on my new 511 Backhoe - the first thing that stood out (almost immediately), was that there isn't a float position on this unit. Am I missing something?
/ 511 Backhoe - No Float Position? #2
I can't think of any backhoe that I have ever used having a "float" position.
/ 511 Backhoe - No Float Position? #4
Your 511, like most Mahindra [ Bradco ] ho's ... has 'float' on the boom/swing lever. The decal for that lever should say 'FLOAT' at the top.. Pushing that lever all the way forward will put the boom into float condition. Your detent could be a little on the tight side, and since it is shiny new, needs to be used a little to make it easier to pop into detent position. You should spend some time reading the operators manual too... not trying to be a smart arse.. but these things are mighty powerful ways to quickly hurt someone or something. Enjoy your spring, Jerry :)
Well....I found it. On the decal, there isn't a float position indicated. However, if you hold the lever in the full foward position, it will "float". It takes a little getting used to. Without the detent, it's a little clumsy, but will work.
/ 511 Backhoe - No Float Position? #6
If you wanted to see clumsy.... you should have seen me operating my ho the first few times... :)
How true! I remember the first time I ran a hoe, it was a completely foreign experience. Had the same experience when I drove a zero-turn for the first time.
That's what made the first hour of running my new 511 so weird - you get so used to having the controls in a specific location with a specific feel. Before I realized that it was there, just no detent, I literally thought, "This sucks - you've got to be kidding me - I never thought to check it on the dealer's lot to make sure it had a float - spent all this money and it doesn't even have a float - I'm taking this back."
And let me tell you, the 30 minutes of seat time today were much better now that I know how to float the dipper.
/ 511 Backhoe - No Float Position? #8
What would you use a float position for on a backhoe?
MarkV
You use the "Float" for trenching.
Excerpt from the Woods Manual.
attachment.php
2020 CATERPILLAR 316FL EXCAVTOR (A65053)
2020 CATERPILLAR...
66in. Skid Steer Bucket (A65640)
66in. Skid Steer...
2016 Ford F550 Crew Cab 4x4 Flatbed Truck (A62613)
2016 Ford F550...
10' Rotary Hoe (A64126)
10' Rotary Hoe...
2017 HAMM H12i PADFOOT ROLLER (A65053)
2017 HAMM H12i...
2016 TEXT 26ft T/A Dovetail Flatbed Equipment Trailer (A59230)
2016 TEXT 26ft T/A...
