5105 no lights when key is switched
   / 5105 no lights when key is switched #1
Isaac7
John Deere 5105
I got a problem with my John Deere 5105 2005 before I took the starter and went to get it fixed the John Deere was good all the lights turned on when the key switched was on and when I tired to crank it'll turn over but not start took off the starter thinking it was the starter then I got my starter fixed today I pout the starter back on but when I give the key to turn no light on dash and not even turning the starter what can It be need help
can it be the ignition switch I also put 2 different battery and put both with good jumper cables and clean the ground terminal or did they not fix my starter right
   / 5105 no lights when key is switched #3
A bad starter won't affect dash warning lights and gauges. It's hard to tell from here, but my money is a a wire that came off the starter along with the battery cable, got pushed around while the removal/installation process was going on, then didn't get put back on. Look for that wire.
   / 5105 no lights when key is switched #4
When you put the starter back in, the wire to feed the main fuse block did not get put back onto the + terminal on the starter. Look for a small wire floating around in the area of the starter ( or you blew the fuse). Cam
2018 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58214)
2018 MQ POWER...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
BOX BLADE (A58214)
BOX BLADE (A58214)
2017 Mercedes Benz GLA SUV (A56859)
2017 Mercedes Benz...
2021 DOWN 2 EARTH 6' X 18' DBL AXLE TRAILER (A52708)
2021 DOWN 2 EARTH...
2017 Kubota L4701 (A57148)
2017 Kubota L4701...
