5103 hydro lift valve problem
   / 5103 hydro lift valve problem #1
usmc5595
I have a 2007 5103 and the rear 3-point lift arms are stuck in the up position!! the Stealer ship says the valve is $800. WTF
Is there anyone who knows how to fix this issue?
Any one have pics of how to pull out the valve in question????
   / 5103 hydro lift valve problem #3
First make sure you don't accidentally have the draft lever up. If it is up it will override the rock shaft(lift arm) lever and will not let them lower.
it is not, i have tried every possible combo i can think of. the parts/service guy said that there was a proces for pulling the valve out and sanding/polishing it, like a "TSB" anyone seen this??
This valve looks complicated from the drawing :confused: I have not been able to get the shredder off the hitch yet
I took the control valve apart but can not figure out what part needs the attention. I sanded the part that looked rusted but when I put it back together as soon as it got to the top (lift arms) it quit and locked at the top.
I need help quick.
Can't afford 800.00 for a new valve
   / 5103 hydro lift valve problem #7
There is also a valve under the seat that controls the drop rate. If it's closed off the 3pt won't drop.
that the same valve i took apart
   / 5103 hydro lift valve problem #9
I am having the same issue and need a fix asap. Anyone know b/f I take her to the stealership?
   / 5103 hydro lift valve problem #10
or could someone please call me 912-282-5291 asap if you can help.
Thanks
Tripp
2012 International 4300 Reefer Truck (A55301)
2012 International...
2018 MACK PINNACLE (A53843)
2018 MACK PINNACLE...
2016 Ford F-750 14FT Flatbed Truck (A52377)
2016 Ford F-750...
KUBOTA M7-132 (A53084)
2021 JOHN DEERE 624P WHEEL LOADER (A52705)
2021 JOHN DEERE...
2017 Rogator RG1300B Dry Fertilizer Applicator (A55302)
2017 Rogator...
