5101E fuel sending unit replace
   / 5101E fuel sending unit replace #1
luvtofarm
Colony Ks
Fuel gauge on my JD 5101E is stuck on full. I suspect the sending unit. Has anybody on this forum had any experience replacing the fuel sending unit on a 5101E? I would be grateful for any advice offered. Thanks for your time.
   / 5101E fuel sending unit replace #2
Are all the other gauges working? I've heard some dashes need replacing so that could be it.
All the other gauges work fine, just fuel gauge won't move off the full mark.
   / 5101E fuel sending unit replace #4
I would start to determine what the problem is. With the fuel gauge wires disconnect from the sender, key in the run position (no need to start tractor), touched wires together the gauge should go to full, with the wires disconnected it should go to empty. Some tractors it goes just opposite of what I just said, that still indicates the gauge is good.
Call your dealer to get the ohm rating of your sender, most likely 0 ohms is empty and about 95 ohms is full. If is possible try and determine how much fuel is in the tank and ohm test the sender. If you have some old electronics (maybe an old fence charger) pull out a 50 ohm and a 100 ohm resistor and connect it to the 2 wires at the sender. Or you could buy the sender part number RE285548. Greenfarmparts.com shows the cost at $50.65.
Attached is a picture of location of sender. If you do need to replace the sender, it comes with a gasket, but I would still put some gasket sealer on. Most likely your tractor is cab tractor, hopefully you can get access to the sender without having to raise the cab a little.
  • 5101efuelsender.pdf
I will check the gauge and sender as you advise. Thanks so much for the info. There is an access panel under the mat directly above the sender that will make it fairly easy to check. Thanks again.
Unused 2025 CFG Industrial MX50R Mini Excavator (A50322)
Unused 2025 CFG...
Great Plaines 2400 Tt (A50514)
Great Plaines 2400...
2017 John Deere 30G Mini Excavator (A50322)
2017 John Deere...
2007 INTERNATIONAL MA025 DAY CAB (A51219)
2007 INTERNATIONAL...
1996 Monon 45X96 Dry Van Trailer (A52128)
1996 Monon 45X96...
1998 Dorsey Trailer, VIN # 1DTP16K29WG052604 (A48836)
1998 Dorsey...
