50hr Hydraulic Filter Change
   / 50hr Hydraulic Filter Change #1
samt
Loganville, Georgia
NH TC33DA
I'm doing the first 50hr hydraulic filter change. What I understood was that this was basically a "dry" change. However, when I started unscrewing the filter, a good bit of fluid started coming out. I've probably lost about ½qt maybe a little more before I tightened it back up. Is this normal? Is there something I should have done before unscrewing the filter? Will I have to do something, other than just check the fluid level, after I've replaced the filter?
   / 50hr Hydraulic Filter Change #2
Yes, it's normal. All you should do is fill the new filter up with fluid before you put it back on which will replace much of the fluid you lose.
Has charger with it. (A51694)
Has charger with...
2016 Ford Focus SE Sedan (A51694)
2016 Ford Focus SE...
Landoll Hauloll (A52748)
Landoll Hauloll...
Wright Sentar (A50120)
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
