50hr Hydraulic Filter Change
   / 50hr Hydraulic Filter Change #1
samt
Loganville, Georgia
NH TC33DA
I'm doing the first 50hr hydraulic filter change. What I understood was that this was basically a "dry" change. However, when I started unscrewing the filter, a good bit of fluid started coming out. I've probably lost about ½qt maybe a little more before I tightened it back up. Is this normal? Is there something I should have done before unscrewing the filter? Will I have to do something, other than just check the fluid level, after I've replaced the filter?
   / 50hr Hydraulic Filter Change #2
Yes, it's normal. All you should do is fill the new filter up with fluid before you put it back on which will replace much of the fluid you lose.
2008 Volvo XC90 Multipurpose Vehicle (A51694)
2008 Volvo XC90...
(1) HD 27ft x 24ft Full Garage Kit Metal Building Frame (A51573)
(1) HD 27ft x 24ft...
2010 Nissan Rogue SUV (A50324)
2010 Nissan Rogue...
2013 International DuraStar 4400 Altec AM547 50FT Material Handling Insulated Forestry Bucket Truck (A51692)
2013 International...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
