5085e questions
   / 5085e questions #11
I noticed a huge difference going from the 15.9 gpm with my Deere to 29 gpm with my MF. The Deere was loader was VERY slow and weak compared to my Massey.
I have ""no doubt that almost doubling GPM output of hyd pump"" will definitely decrease FEL cycle time & improve performance!
   / 5085e questions
Well I found the problem, looks like the tilt outputs color caps had been reversed. I connect them correctly and everything works great now.
   / 5085e questions
now one more question for you all, It has the normal exhaust on it, but I find it gets in the way looking at the loader. Do any of you who have one of these have the A-post exhaust? If so, do you like it off to the side?
Thanks again
Scott
   / 5085e questions #14
I had the normal exhaust on mine as well, in the way, turned loader black from soot and couldn't run with the loader up for too long for fear of melting hoses. My new tractor has corner post exhaust, way better! You don't even know its there. If you can upgrade to the corner post exhaust for a few hundred bucks or less I would say it's worth it. Should probably be standard equipment anyway.
   / 5085e questions
Thanks for the tip. Since the pie comes so low on the corner exhaust how do you tun your hydraulic hoses so they don't get so close?
FORD DEXTER TRACTOR (A52708)
FORD DEXTER...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2022 Coras Predator Steel End Dump Trailer (A56435)
2022 Coras...
2017 VOLVO VNL TANDEM AXLE SLEEPER (A58017)
2017 VOLVO VNL...
New/Unused CFG Industrial MX15RX Mini Excavator (A57453)
New/Unused CFG...
WHIRLPOOL WASHER & KENMORE ELITE DRYER (A54757)
WHIRLPOOL WASHER &...
