5075e Transmission Hard Shifting
   / 5075e Transmission Hard Shifting #1
LoudonNH
Culpeper, Virginia
2017 JD5100M, 2014 JD5075E, 2017 JD3039R, 2023 JD X730
Here's a new one:
My new 5075e with Power Reverser has developed a new issue. The transmission slams in and out of gear when shifting between forward and reverse, unless the tractor is idled completely down and not moving. This is happening in all three ranges and all four gears. My dealer is going to send his service man out to recalibrate the transmission. It's my understanding that I should be able to shift between forward and reverse at any RPMs and in any gear.
I'm not sure but it seems as if the problem gets worse the longer the tractor runs. Anyway, apparently it's a computer issue and should be repaired before any damage occurs.
have any of you guys had this issue?
   / 5075e Transmission Hard Shifting #2
Not a good thing... I've not had that problem. Sounds like the "shift modulator control" needs to be re-flashed or programmed.
Don't imagine that it will be too extensive a job.
Appreciate the pics. Thanks.
AKfish
2006 Chevy Trailblazer (A47384)
2006 Chevy...
2016 KLEEMAN MS192 MOBILE SCREEN (A51242)
2016 KLEEMAN MS192...
1994 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A49461)
1994 Mack CH613...
2025 GIYI GY-X380 Trencher Mini Skid Steer Attachment (A50322)
2025 GIYI GY-X380...
New 4-235/80R16 Montreal Trailer Tires (A50774)
New 4-235/80R16...
2024 Case IH Magnum 380AFS CVX Connect MFWD Tractor (A50657)
2024 Case IH...
