5075E factory MODS
   / 5075E factory MODS
It comes with that fine looking dog?:D
Is the glass "fixed" and you just add the hinges & hardware to the std glass?
Yea, I have to remove some brackets that hold it in place, and bolt on the hinges, etc. And it has a few plastic plugs in the glass that will be removed. Picked up with instructions at the dealership yesterday.
RedNeckRacin, on mine you can tighten or loosen the torsion spring to match your weight. Even my old 685 Case IH has one. ;)
And Charlie says, "Thanks!" :D
   / 5075E factory MODS #12
I have mine CRANKED all the way down and I still can bottom out the seat from time to time. I need to just bite the bullet and get the air seat upgraded at some point.
Does it have a height adjustment too? Yea, air is nice. What I have on the 8310. Both other large tractors have hydraulic seats in them. They go to leaking, I will replace them with air. Nothing like seeps to make a mess.
I have the RH door kit installed. Seems I have to do a bit of grinding to slot the holes on the upper hinge (ugh!) Also ordered a rotating beacon and a horn kit! :cool:
   / 5075E factory MODS #14
I don't think it has a height adjustment, I do have the fore and aft I do believe. I'm not a big guy (220-230) so I'm a bit frustrated with the seat but not enough yet to do anything about it. I'm really debating on getting some more suitcase weights, and a radio installed first. I usually just listen to music on my cellphone but in the cab would be nice. I also thought about possibly installing a CB but I'm not to serious about that yet either.
   / 5075E factory MODS #15
My butt must have lead in it because a good set of bumps and I can bottom out my seat!
You ain't by yourself, I was harrowing and it got rough and I heard a loud noise and bam my seat bottomed out, I think I broke my spring, I need to do some looking and see if the whole seat comes out easily so I can figure out what happened.
   / 5075E factory MODS #16
A bit off subject but... can anyone tell me the difference between a 5075M and a 5075E?
   / 5075E factory MODS #18
Sorry to hear about the broken spring, I really don't think that they made the spring suspensions nearly strong/stiff enough.
   / 5075E factory MODS #19
I got the seat out and went to the dealer, seems the seat I have is rare and manufactured by Sears, yep that's what it says right on the seat, seems the normal seat has 4 springs and this one only has 2, but they did show a heavy duty spring kit and it's on order.
RH door is functional, fenders, sorted with some modification to the brackets. Newly installed rotating beacon is also functional.
Driving it to the dealership to have some warranty work done tomorrow.
The only things left to install are the shuttle modulator and the horn.... Unless I break down and buy and rear window wiper... And I am pretty weak...
Oh and this... http://www.greenpartstore.com/thumb...ereparts/ag/2014/bre10152.jpg&maxx=300&maxy=0
2016 Nissan Pathfinder SUV (A53424)
2016 Nissan...
UNUSED FUTURE MINI EXCAVATOR HYD AUGER (A57193)
UNUSED FUTURE MINI...
UNUSED FUTURE 44" CAT305 EXCAVATOR RAKE (A57193)
UNUSED FUTURE 44"...
UNUSED WOLVERINE TDB-11-66W 66" BUCKET (A57193)
UNUSED WOLVERINE...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2007 International 4300 (A53314)
2007 International...
