5075E 400 hour review
   / 5075E 400 hour review
The shifter boots never appeared to me to be real high quality rubber but no failure yet. But the tractor is parked inside 99.9% of the time so is only likely to enter only from washing. Thanks for the reminder. The sticky RPM gauge at the dash is pretty annoying.
I "think" 2450 rpm is PTO rpm on my machine and it will do that plus a little. But if it wont spin it at 2450 another 100 is not likely to help. I did not get the Power Reverser. The smooth synchronized in line shift from R to 2nd even while rolling was/is very handy for the chores I do. No loader on this tractor but I do use a heavy Servus/Rhino 8ft rear blade to maintain gravel farm roads and clean off a heavy use gravel feed pad.
   / 5075E 400 hour review #13
You can get it with Sync Shuttle too. Or at least you could. My 5310 had it and it was SS. I would never buy another tractor without it no matter what I had to upgrade to to get it. Thankfully my 5090 came with it.
   / 5075E 400 hour review #14
Pretty sure that's engine RPM. I don't think a 540 RPM PTO will turn 2450.
   / 5075E 400 hour review #16
Do you other 75E owners see 2450 engine rpm ?
   / 5075E 400 hour review #17
I think my 5090E is around 2250 when it's not in EPTO. I don't know about a 75 but 2450 is feasible.
   / 5075E 400 hour review #18
The New 75E I tried on the dealer lot wouldn’t turn 2450rpm w/o PTO even engaged :(
   / 5075E 400 hour review #19
Yea, not sure. Do those have the digital dash or a tach? My 5310 tach had tick marks for EPTO and reg PTO.
   / 5075E 400 hour review #20
75E I tried was analogue engine tach
Probably a year & a half ago.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
(NEW) SOUP KETTLE (A58374)
(NEW) SOUP KETTLE...
11' x 19' All Metal Carport (New/Unused) (A59225)
11' x 19' All...
(INOP) 2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
(INOP) 2015 FORD...
2007 Capacity TJ6500T Wet Kit T/A Yard Dog Toter Truck (A55973)
2007 Capacity...
New/Unused 2025 CFG QK18R Mini Excavator (A57453)
New/Unused 2025...
